Well im getting there, new PVC board from China was programmed wrong... put the old board in with the new adjusted sensors now its working. No more fault codes.
Last thing is the travel selector.
It seems to be stuck in high. Checked the travel speed solonoid, has 23 ohms like it should. The travel speed connecter always has 24-28 volts all modes, whether it's key on or running, both low and power mode engine speed. Shouldn't this change from 0 volts to 24 volts depending on turtle or rabbit to activate the solonoid? What is there to check next?
