Ah the Magic Smoke, anyone got a Good Vendor for replenishment tanks? I do not have access anymore!!!
It doesn't make sense to me. How far up a 6% can the battery get you at 80k? Seat of my pants says not very far. You will be running direct generator to electric most of the way up the grade.
Also what I did not see was the giant electric heating element they must need for downhill braking after the batteries get 100% full from regeneration.
I've often wondered that myself. Whatever it is they started spraying on the roads here is eating the concrete up on people's garage floors. That can't be good for wiring. I mean salt was bad enough that you're re-wiring the tail lights on the heavy trucks every spring anyways, regardless of how well you try and seal it all up.Seems Teslas and Salt Conditions do NOT like each other. Aftermath of Hurricane Ian is Tesla Fires from Corrosion Onset of the batteries.
Would concern myself as to Severe Salt usage of road departments in winter and how that will affect these.
Florida official: EVs starting fires in hurricane aftermath (newsnationnow.com)
I've got one of those aluminum Fords and winter of 2020 I accidently opened the door into a post at a gas station and put an inch long split in the paint where it got hit. Numerous pressure washes and 2 winters on it since then and the paint has yet to bubble, blister or flake in that area.How does aluminum fare with the road salt?
Several times a year I shove the garden hose into each hole in the frame and flush out everything. Same with the fender wells, inside the box sides, door gaps etc. Takes a bit of time but I never have rust issues on my vehicles.Ford tissue paper F150s have a steel frame issue. Boxed to make tin stronger also holds all the crud to enjoy chewing on it. Local body shop has changed several full frames under ten years age and all under 80,000miles. Do not for once will believe Tesla cars will survive five to eight years in midwest full time use due to salted roads and critters that enjoy munching the soy based plastics in them.
They will eat the Ford vehicles too, except they get an extra boost to gnaw away faster and longer...Ford tissue paper F150s have a steel frame issue. Boxed to make tin stronger also holds all the crud to enjoy chewing on it. Local body shop has changed several full frames under ten years age and all under 80,000miles. Do not for once will believe Tesla cars will survive five to eight years in midwest full time use due to salted roads and critters that enjoy munching the soy based plastics in them.
