Gang,
Picked up an old euclid rear dumper. Cummins NHRS engine and a Fuller 10-F-1220 transmission. When I push in the clutch either starting out or to shift when moving, its like the main shaft wont stop rotating and the clutch is sticking and not going free in the pressure plate/flywheel. The tranny gears grind shifting into any gear. I have checked all travel and you can see the throwout bearing press up against the fingers with good travel.
Before I drop the tranny and tear into things, any other things to consider? AM awaiting for my service manual which should be here in a couple of days. If I start the truck in gear I can drive it no problem in a single gear. There are no odd noises and shifting itself is fine with the engine off.
My parts diagram shows a very simple transmission to take apart. I know in my old JD dozer there is a gauge to set the clutch pressure plate finger height. The grinding gears are annoying me to death to get an idea of issue before I climb under it and take the tranny out. Wisdom appreciated.
The only other thing I could see is that the input shaft had a bearing in it, and if it is stiff, would cause the main shaft to continue to rotate....but with no clutch pressure, you would think it would settle down.
Krusty,
Krusty,
