Engines not reving up or shutting down coming from auto idle
Discussion in 'Excavators' started by ROAMER_AUS, Sep 24, 2021.
  1. ROAMER_AUS
    ROAMER_AUS Well-Known Member
    Sep 6, 2018
    96
    Croatia
    Hi all,
    Just a general question so to speak. I had 4 cases recently where engine auto idle function is active, you activate a command, and if you don't do it gently at first and give engine a second to come back to working RPM it will shut down, or won't be able to rev up, but struggle in low RPM, you then ease off on the joystick, revs come up, and off you go working normally again. Like engine needs more of "something" to rev up. Excavators were:
    Litronic 914
    Volvo EC360B NLC
    Kobelco SK250-8
    Takeuchi - forgot what model
    By changing air and fuel filters, problem was cured only on Volvo, on others problems remained. Now customers in all 3 remaining cases stated they will stop using auto idle temporarely as they can't spare time to investigate this further, but eventually they will come back to get the problem fixed.
    What are your experiences with this sort of a problem?
  2. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    4,004
    Mechanic
    Will county Illinois
    Do the other 3 have pump, line and nozzle, or common rail or electronic fuel injection? Just looking for a common denominator
    mg2361 likes this.
  3. ROAMER_AUS
    Sep 6, 2018
    96
    Croatia
    No commonrail / electronic on any of them
  4. funwithfuel
    Mar 7, 2017
    4,004
    Mechanic
    So the other 3 run off a stepper motor for throttle control?
    mg2361 likes this.
  5. heymccall
    heymccall Senior Member
    Feb 20, 2007
    3,113
    White Oak, Pa
    Well, I could probably help on the takeuchi. Model AND 1st 4 digits of the serial number.
  6. Kobelco ireland
    Kobelco ireland Senior Member
    Feb 29, 2016
    273
    Mechanic
    Ireland
    On the kobelco 250 - 8 what is your low idle set to. If its too low it can cause the rpm to be slow to pick up. It might just need to be recalibrated
  7. ROAMER_AUS
    Sep 6, 2018
    96
    Croatia
    I'll have to get back to you on this one. I didn't note down any of the details as I was basically called in as I was passing by, and I was short on time. As service wasn't done on it for a while as they said, I advised to change filters and oil and see from there. They reported back that issue still remains after this.
  8. ROAMER_AUS
    Sep 6, 2018
    96
    Croatia
    Step motor controls.
  9. ROAMER_AUS
    Sep 6, 2018
    96
    Croatia
    To be honest, I didn't spend much time investigating problems on any of these 4, as they were all short on time and itchy to keep working, and auto idle wasn't an issue for any of them. I just wanted to get a bit more of general idea what do you guys usually come across to be cause of the problem for these issues. Speaking to some more experienced mechanics, 90% of cases as I was told issue is fuel or air (not so much) supply to the engine.
  10. ROAMER_AUS
    Sep 6, 2018
    96
    Croatia
    Actually guy just called me this morning about some engine overheating issues happening in last few days apparently, so I'll be visiting him in next few days and I'll check the RPM setting.
  11. ROAMER_AUS
    Sep 6, 2018
    96
    Croatia
    My memory is just refreshing now. Takeuchi didn't have stepper motor, and I think it is commonrail system. Sorry, this was few months back and I can't be sure 100%.
