Engine Replacement
Ghana
I have a 320bl excavator with a 3066 Mitsubishi engine I replaced it with 3 different 3116 engines but all overheats,gave it a bigger water tank and fan blade but it still overheats
I want to replace the engine with a different one apart from the 3066 and 3116
I learnt Cummins engine can fit into it
Anyone with an idea about it
Please help a brother out
Bls repair
S E Pa
Equipment operator,mechanic
I know this sounds silly but did you change temp gauge and sending unit. I like to back it up with a mechanical gauge. Use a temp gun to check radiator and hydraulic oil cooler.
