Engine oil won't drain 1998 Case 580 SL series 2
bigislandpaul
farmer
This machine is new to me. I am trying to change the engine oil in a Case 580. I opened the drain plug and nothing comes out. It looks like there is a valve of some kind inside the drain plug. The dipstick says there's oil in it. I tried running the engine and loosening the oil filter. What am I doing wrong? I looked for a another thread but maybe this is too simple a question. Thanks for any help you can give.
bigislandpaul
farmer
Sounds like a drain valve. Probably just need the adapter to thread into it to unseat the checkvalve.
Thanks, I'll see if I can find one. Strange, the manual doesn't mention it, only remove oil drain plug and oil filter.
bigislandpaul
farmer
I think you are
I think you are right. Here's a photo of the drain plug with the cover removed.
