engine make?
petepilot
central shenandoah valley va,
I never heard of a 7.9 either .if it does have a v6 all I can think of is that someone transplanted a turboed 653 in it . I should have some pics. in a day or two we`ll see then` its about a 100 miles from me
RZucker
Wherever I end up
Mechanic/welder
6V-53 was only 318 cubes, what is that in liters? 5.0?
6V-71 was 426 cubes.
RZucker
Wherever I end up
Mechanic/welder
you`re right methinks the guy trying to sell it to me doesn't know what he`s got
Methinks you are correct. :) Depending on the Hp rating and your intended use, make sure its got a lot of gears. Mines a 210HP with a 6610 transmission at about 22-23K lbs. and you get to know every one of those gears. :D
  • Like
Reactions: DB2
Spud_Monkey
Your six
Decommissioned
Only Detroit they would of stuck in there is the 8.2L fuel pincher which wouldn't surmise to the V6 since it was a 500 cubic inch engine.
RZucker
Wherever I end up
Mechanic/welder
Yep. 8.2L, had a few of them in service trucks. A customer tried one in a tandem F800 pulling a smallish equipment trailer... No Bueno, it now has a Cat 3208T that has been doing the job for several years.
Lots of people don't know what a V6 is. My bet is you show up and it turns over fine but won't crank.:D
I don't think Ford used the 8.2 detroit V8 that late, maybe?
Steve Frazier
Founder
Staff member
LaGrangeville, N.Y.
Construction company I worked for had an F800 with the little Detroit in it, the thing was gutless and it sounded just like the 3208 Cat. I actually thought that’s what was in it until I peeked under the hood.
I’m betting the truck you’re looking at has the Ford I6 in it too. From what I’ve heard they were no powerhouse but were pretty reliable.
John C.
I seem to recall Cummins had a V6 for awhile. I remember seeing them in log skidders. I recall something about 378 on the tag. It sure wasn't 7.9 liters though.
crane operator
sw missouri
Most likely its a 5.9 cummins or a 7.8 brazilian. If its diesel. There are a few 8.3 cummins, and a occaasional 3208 in the late 80's. If its a v style engine, I bet its a big gasser, and the last two cylinders are hid under the firewall.
