Hi everyone
The following machine has engine starting problem
Machine Details:
Motor grader
Model: 140H
Serial S/N prefix. CCA
engine model : 3176
Problem: engine cranks , but will not start
Checked the following CAT ET ,but still not started.
-Did injector solenoid test, all are OK, they have good click sound,
- When cranking the rpm reading in cat ET screen is 180
- both primary and secondary sensors are reading 180rpm, I checked them one at a time.
- took the injector nozzles to injector testing machine shop, all are fine
- fuel pressure has enough pressure
- no active codes
Can anyone suggest any possible solution?
Thanks in advance for your help
Machine Details:
Motor grader
Model: 140H
engine model : 3176
- no active codes
