Elevation Calculations
Discussion in 'Jobsite Coordination' started by Dozerman85, Nov 27, 2016.
  1. Dozerman85
    Dozerman85 Member
    Nov 7, 2016
    8
    Waller, TX
    I've been using site levels and lasers for years now. I'm fairly well versed with them. However, I am currently working on a project that has me stumped.
    I have 4 catch basins with 24" storm drain in a line. I am trying to find the elevation of each catch basin.
    My benchmark is set at 157.91. If I set the benchmark on my laser rod and it's set at 3.25(for example), if my 1st basin shoots a 4.50 on my rod, I calculate the difference of 1.25. I then subtract 1.25 from 157.91 and get the elevation of 156.66 for my 1st basin. My question is, if my 2nd basin shoots a 5.50 on my rod, do I subtract the difference between 4.50 - 5.50(1.0)from my original benchmark, or do I subtract it from my 1st box elevation of 156.66?
    I really hope this makes sense as it's kind of hard to explain.
    Anybody? Thanks a bunch in advance.
  2. lumberjack
    lumberjack Senior Member
    Dec 25, 2011
    972
    Columbus, MS
    Your bench mark is your bench mark, that's what you add/subtract from, you can have an infinite amount of points on the plane, but they don't effect your bench mark.
  3. Dozerman85
    Dozerman85 Member
    Nov 7, 2016
    8
    Waller, TX
    That's exactly what I thought. Since the benchmark never changes, that's what I would always refer to.
    I greatly appreciate your reply!
  4. Oxbow
    Oxbow Senior Member
    Nov 22, 2012
    842
    Idaho
    Same result, but you might consider calculating your HI (height of instrument) and working off of that figure, rather than keeping track of one rod reading, and then working off of that rod reading.
    In your example:
    BM=157.91, Rod Reading @ bench mark = 3.25, Height of instrument = 157.91 + 3.25, or 161.16. Use this and then subtract the designed height of the basin to figure what the rod reading should be if at grade.
    If your first basin is designed to be 156.66, then subtract that from the HI 161.16-156.66=4.5 rod reading. For the next basin subtract the design height from the HI again.
    As I mentioned, you will get the same result but it should cut down on mistakes made from trying to remember rod readings. If you need to move your laser, then shoot the bench mark again and re-figure the HI.
    This method sometimes seems slower than just comparing the previous rod shot, but it has helped me to save time by not making (as many) mistakes. I also have finally got in the habit of writing all these things down rather than trying to keep them in my head, which also has cut down on mistakes. The old noggin ain't what it used to be!
    M Silva likes this.
  5. oceanobob
    oceanobob Senior Member
    Jun 13, 2010
    530
    general contractor
    oceano california
    I get white primed 2x2s from the lumber yard. When at the bench, I mark the 2x2 at the laser bracket with a 0, or, the benchmark number. Off I go to the next location and move the laser receiver bracket to the new location and then literally measure. A tape measure with inches in tenths facilitates this.
    Same as the other way, just less math.
    Agree on writing down. 3x5 cards help this task.
  6. Dozerman85
    Dozerman85 Member
    Nov 7, 2016
    8
    Waller, TX
    This is a big help, too. I've never done it this way, but it definitely makes sense and I understand it. I'll try it tomorrow.
    I wear shirts with pockets, where I keep a pen and paper. I have to write all of these numbers down or it just becomes too much. Thanks for your help!
  7. Dozerman85
    Dozerman85 Member
    Nov 7, 2016
    8
    Waller, TX
    I use a tape measure constantly. It's way too easy to screw up the tenths/inches conversion. Thanks for the response!
  8. Hoppsxc140
    Hoppsxc140 Member
    Jun 4, 2011
    14
    Washington
    I've worked hard with my guys on using elevations with a Lenker rod. It cuts down on the mistakes by taking all the math out of it as the guys just have to match the number on the plans with the number on the rod. They do cost a little bit, but if taken care of they last and the time saved pays off.
  9. CM1995
    CM1995 Super Moderator
    8,425
    We do the same when setting storm structures, pipe and grade elevations. I stress to my guys to always reference the bench mark, not the last structure set in order to cut down on mistakes.
    For example the day before we set two manholes and ran 100' of pipe. At the start of the day set up the laser, reference the bench mark and check the last structure set. If there is a discrepancy re-check your rod on the BM and find out what's wrong. It helps to cut down on errors.
    I use this an orange field book like this - http://www.engineersupply.com/elan-...2j19JZRKWPpw4o911fkZ1r6b4MljmPTGw3hoCoXfw_wcB
    Each day of pipe laying is recorded in the book with date and job. All the calculations for the day are written down in the book.
    I like the Lenker Rod, going to check into that. Looks like a simple way to reduce math errors and speed production.
  10. Shimmy1
    Shimmy1 Senior Member
    Aug 14, 2014
    2,343
    North Dakota
    I agree with checking the benchmark against last structure at the beginning of the day, but if you're dealing with structures such as manholes, once it's set it's essentially a benchmark, unlike floating grade such as a building pad or excavation. Of course, this all depends on how competent your guys are with math. :)
  11. bobatack
    bobatack Member
    Feb 20, 2012
    21
    Ontario, Canada
    Lazer head with slope capability helps to keep calculations to a minimum
  12. CM1995
    8,425
    Agreed. If your last structure was out a little sometimes you can adjust the next one depending on the flow line to get back to grade. Don't ask me how I know this...;)
  13. Shimmy1
    Aug 14, 2014
    2,343
    North Dakota
    That's funny you mention that........I was going to ask you about "oops" situations, because they happen to the best of us. I've did it both ways, put just a tad less slope for sometimes a few runs to get back to zero, or just leave it alone if it's not going to matter anyway.
  14. CM1995
    8,425
    It happens to the best of us. When it does happen and it will, if the water still runs downhill that's all that really matters.;)
    Shimmy1 likes this.
  15. Bls repair
    Bls repair Senior Member
    Jan 21, 2017
    447
    Equipment operator,mechanic
    S E Pa
    When using a laser or instrument remember to have to checked. I have had quite a few that were off,had to redo pipe line or redo slab on grade.
