I bet you don't have a keel cooler on your loader.
Bob
That red engine sounds a bit lumpy at idle speeds
What is on that motor is a expansion tank , a keel cooler is a heat exchanger in the bottom of a boat.He thinks I need to leave that on there, I told him it would come off and I’d set it up the same as mine.
Bluox knows his stuff. I’d defer to his comments.
Well then it might be a former marine genset .Option plate says it’s “power base” application, it has a 4 in the 4th digit place. Marine would be a number 2 in the 4th digit place.
If its a water below port block
