Eaton 13 Speed getting stuck in neutral
Cheap "old" Geezer
Have gotten away with cleaning the shuttle at times
A little silicone grease on those orings is good too
Used to save the tubes of that when supplied with trans valve kits, they still put those in the packages?
This may have been mentioned but I didn't see it. Have you washed out the sintered brass filter under the 1 1/2" plug on the trans. air regulator yet?
Not yet, because the high/low works. when the splitter starts working then the owner can pickup a new regulator and shuttle for splitter. You brought that up before in a thread
on HTF three years ago.
Cheap "old" Geezer
Hate to think it, could also have loose/broken/otherwise damaged pins in the clutch/synchro assembly, hanging it up when shifted, am hoping NOT.
alaskaforby4
Alaska
Owner Operator
I cleaned as much as I could last night, I removed that brass plug opposite of 5/32 line, but was unable to remove the unit inside. I could grip in with needle nose but in wouldnt budge. I did notice the brass plug had a machined hole in it and air was escaping through it very slightly. I lubed everything else up that was mentioned and the splitter/od has a very positive clunk now when operating. Going to test it out today. If it works I will be able to replace it! thanks for the helps
Cheap "old" Geezer
This is the little device you did not get out, really need to get that out and inspect/lube if not replace. p/n 19974
https://holsttruck.com/parts/details?part=80900815
mitch504
Andrews SC
Actually, his first post said the problem occurred most often with the splitter, but with the high/low also. I try to mention it any time air shifting problems come up, because washing that filter is a quick, cheap way to rule out one cause of inadequate air, and just something the old junk I see needs periodically. :D
alaskaforby4
Alaska
Owner Operator
The splitter seemed to work OK the Hi/low did malfunction on me tho. Where is this filter before I jump to bigger problems
Cheap "old" Geezer
View attachment 197290 View attachment 197291 View attachment 197292 Excellent thanks, I think I’ll opt for a new one. This one is pretty crusty trying to get off. Ive found some more info on the on my neutral problem. It seems the splitter sometimes does not dump into the low side. And stays high, so if I shift into the low side (1-4) where there is no split available it makes terrible noise and stays in a neutral. So which actuator is the splitter and which line should I squirt some lube?
Under the top cap of the multiline regulator in the last photo.
file:///C:/Users/ddm50/AppData/Local/Packages/Microsoft.MicrosoftEdge_8wekyb3d8bbwe/TempState/Downloads/2074-Air%20filter%20regulator%20assembly%20(1).pdf
Cheap "old" Geezer
There is also a sliding lockout dowel that prevents the air shift Hi/LO and LO/Hi behind the valve on the side of the case, if it gets gummy and the spring fails to retract it the system will do the same. By the outward appearance of your gear box I would have a look at that as well.
Page 10 and in the manual as to location/passenger side right below top cover.
file:///C:/Users/ddm50/AppData/Local/Packages/Microsoft.MicrosoftEdge_8wekyb3d8bbwe/TempState/Downloads/super-parts-book%20(1).pdf
Well there are days if I was a #3 things would be better as less responsibility for me.;) And I'm not trying to humble anyone and I fu^k up a enough sh!t anyway all by myself.
alaskaforby4
Alaska
Owner Operator
Hello DMiller, there is no photo attached. Is this a file or manual I can find somewhere?
Thanks
alaskaforby4
Alaska
Owner Operator
Ah ha! This is where it’s at! I can hardly wait to try this! I have found that alcohol tends to clean out the air lines and send it all downstream... I’ll take a picture of evidence
