Eager Beaver deck replacement
Discussion in 'Trailers' started by rickw, Aug 17, 2018.
  1. Willie B
    Willie B Senior Member
    Jan 3, 2016
    1,288
    Electrician
    Mount Tabor VT
    I bought a C65 in 2006. It was 30 years old, 48000 miles, and had been stored indoors. The PT deck looked OK at the time, but it was as fragile as styrofoam. The steel frame of the dump body had been given a plastic overhaul, and under plastic, and paint, there was nothing left.
    I rebuilt the steel, and replaced the PT with Red Oak I cut on my own property. I had enough 2-1/4" Oak sawed to replace it once. Hurricane Irene stole my second round of oak, and 9 years later it was again falling apart. I now have steel. It seems to be holding up well.
  2. Willie B
    Jan 3, 2016
    1,288
    Electrician
    Mount Tabor VT
    My 9 ton got decked with PT, and I heavily greased all the contacted steel with some old Texaco Rustproofing Compound L. It held up well for several years with no evidence of rust.
  3. rickw
    rickw Well-Known Member
    Dec 4, 2012
    192
    ohio
    Well we got the old deck off the trailer. came off really easy do to boards being in bad shape. just cross cut w/ circular saw and tapped boards out to dislodge washers. I thought I was going to take a impact and just unbolt it... I learned real quick that was not going to work. I wanted to save the washers because there are about 200+ of them. On Ebay they are $1 EACH! So I called Southeastern Equip. (Eager Beaver dealer) And got them for $.35 each. First time ever dealer was the cheapest place! Now it is at my brothers to get blasted and painted before bad weather sets in. We have a big enough heated shop to back it into to work on it this winter.
    td25c likes this.
  4. fast1buzz
    fast1buzz Active Member
    Oct 2, 2018
    34
    Retired Heavy Haul Company owner
    pueblo co
    Most trailer MFG's now are using Apitong wood on RGN's/Lowboy's. The wood is as tough as they come. My local lumber yard got some to redeck one of my trailers. Stuff even is not phased by sheepfoot rollers which will destroy an oak deck.
    AzIron likes this.
  5. rickw
    Dec 4, 2012
    192
    ohio
    Is that material as good or better than oak for rot resistance?
  6. AzIron
    AzIron Senior Member
    Jun 15, 2016
    663
    Az
    Apitong is much better
    It is a dry climate here but I have a trailer with apitong that is over 20 years old
  7. fast1buzz
    Oct 2, 2018
    34
    pueblo co
    I had some of the small pieces that were to short to use I tossed those and the old oak that came off the trailer behind the shop thinking I might use the stuff else where[probably not in this lifetime LOL] after 10yrs on the ground the oak has had it the Apitong looks like the day I put it there
  8. Delmer
    Delmer Senior Member
    Jan 4, 2013
    5,880
    For the materials price, I could replace the oak several times and still be cheaper than Apitong. Labor and hassle would have to be worth a lot for it to be worthwhile. Also depends on the wear and tear you put the trailer through, in addition to the rot resistance. And by Oak, I mean white oak heartwood, red oak will rot as fast as most hardwoods.
  9. rickw
    Dec 4, 2012
    192
    ohio
    I finally got deck replaced. I got White oak sawn locally. I make it nice that the trailer fit into our heated shop:). I bought the deck washers from local case dealer for 1/2 of what they were on ebay. It was not a bad project to complete at all
    td25c likes this.
  10. rickw
    Dec 4, 2012
    192
    ohio
    The 1 1/2" thick rough sawn green white oak cost $525 total. Washers were about $100 and I bought the grade 5 2 1/2" bolts at Rural King bulk, maybe $80? Then I replaced the jack. It was old and the bottom slide out was jammed and did not come out hence the Jenga stack of blocks under it. I had $1000 or a little less in the whole project doing it all myself except I unbolted jack and a buddy cut jack off plate and welded new on for $20
    td25c likes this.
  11. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    Nice work rickw !
    rickw likes this.
  12. fast1buzz
    Oct 2, 2018
    34
    pueblo co
    That worked out nicely rickw. Must say the oak should do just fine.
    rickw likes this.
  13. RovertMolins
    RovertMolins New Member
    Apr 17, 2019
    1
    United States
    This is a rather complicated decision because I had a similar problem and in the end I had to sell my trailer...
    rickw likes this.
