This is the monitor of E385 New holland excavator, I needed a description of these button on the lower part of the monitor. I wanted to know if there is a key combination, so we can check error code or monitor RPM, fuel rail pressure or any other system like electrical or hydraulic system...
The machine run good but sometimes I have engine stall with slight black smoke. Also there is vibration when engine idling at 1050rpm, is this normal vibration on common rail system.
Is there any software and a corresponding connector that we can connect in the cab of these machine to see what's wrong in the engine.
