Dynahoe Backhoe
Discussion in 'Tractor/Loader/Backhoes' started by Cold-Oil, Nov 10, 2019.
  1. Cold-Oil
    Cold-Oil Member
    Mar 20, 2010
    9
    Mechanic
    Alaska
    I have a 1975 Dynahoe 160 and am looking for the Wagner part number for the wheel cylinders. I would like to have them on hand when I disassemble the rear wheel planetary units to repair the brakes. Thanks in advance for any help!
  2. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    3,544
    s/e Heavy equipment operator
    Western Washington
    Not sure if these apply to yours without a serial number.... but here is page 45-46 of the parts manual for my 160.
  3. Cold-Oil
    Cold-Oil Member
    Mar 20, 2010
    9
    Mechanic
    Alaska
    Thanks so much for your efforts! I do have this manual and wish they would of also used the manufactures part numbers. I am purchasing a master cylinder($300 plus $80 shipping) ouch! then I am pretty sure I will have to replace the wheel cylinders also. But one thing at a time!!
  4. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    These are generic cylinders... any decent truck parts place(with older guys there) will be able to get rebuild kits for them... of even the makers parts for a fraction of that.
    Some of the older dealers used to be able to cross the hydynamic munbers to OEM also, unfortunately the ones around here went out of business a few years ago.
  5. Mother Deuce
    Mother Deuce Senior Member
    Jul 17, 2016
    1,381
    New England
    Really liked Bob Fray...I found a Wagner master cylinder number for a 160. Wagner #17095 in a forum from 2005 see images. These guys we’re getting their brake parts at Napa by bringing them in and doing physical comparisons with Wagner stock. It is said that Minnparr has the numbers and parts. There is also a Dynahoe owners group on Yahoo that exchanges info. 43F50D5A-0743-437A-87C0-88323478B2D9.jpeg A9E1E066-8BD6-43D5-AB64-FE743A0E9F90.jpeg 8C74BFE4-0215-4992-9AF4-D0FB423EB8EF.jpeg
    Ronsii and Tinkerer like this.
  6. 1693TA
    1693TA Well-Known Member
    Feb 28, 2010
    196
    FAA Radar Engineer, (Retired)
    Farmington IL
    Remove that master cylinder, remove the internal snap ring which retains the guts and pull it apart. Hone the bore, install new rubber cups and teflon washers, (easily available at "older" parts stores) and put it back together.
    I had a 160 Dynahoe w/353 Detroit Diesel. Purchased it just to get it running and sale but had to rebuild the service brakes along the way. Very simple built machine using mostly off the shelf parts. Bucyrus kept it simple with them. Mine had a Borg-Warner transmission, Commercial-Shearing main hydraulic pump, and used Wagner service brake parts. I purchased everything needed at the then locally owned Carquest auto parts store.
    Ronsii and Mother Deuce like this.
  7. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    4,704
    On A Riverbank in IL. USA
  8. Ronsii
    Jun 26, 2011
    3,544
    Western Washington
    Yeah MD, Fray equipment was the go to place for many years :) I got a few things there and plenty of info.
    The issue with my master cylinder and quite a few others so I found from digging around was the reed valve on the 'bone' would fracture and even though you could get the seal kits all day I was never able to find the hard parts(I really didn't look that hard... had too much else going on) but yes, most of the parts are generic simple truck parts.
    I had to replace the ring and pinion once and finally found the actual manufacturer in seattle, forget the name but they're at the end of 599 where you switch over to get on the draw bridge(1st ave)
    Mother Deuce likes this.
  9. edgephoto
    edgephoto Well-Known Member
    Aug 14, 2019
    141
    Stafford, CT
    @Mother Deuce I see you are a Mac guy. Command-Shift-4 will allow you to snip screen shots.
  10. Brad L Hornberger
    Brad L Hornberger New Member
    May 21, 2020
    1
    Williamsport pa.
    sorry for butting in, but had anyone ever had to remove a steering wheel on a dynahoe 160? I think my linkage broke to the rod. I removed the nut under the horn. Won't budge
