snonut12
Charter Member
Hey, first time posting here but I'm sure most of you are familar with me. Anyway here's the story: I currently have a 6x10 low profile 7000# dump trailer which is one of my best investment. However I am having a couple problems involving with ground clearance and limited capacity. It seems that the local manufacturer of my trailer has put the pivot points a bit too far away from the rear end of bed (18") so when dumping fully loaded, the bed will bottom out and it's not easy getting my truck to drag until the load is out. This is especially a serious problem when dumping on grass/field because I can only dump halfway before it will touch the ground. Another problem is I can only haul 2 yards, maybe 3 of top soil or gravel. So I'm pushing the limit when carrying a bit more than that. Although most of times I use the trailer for brush and leaves removal I still could use the extra capacity for the heavy stuff.
So I am thinking about something like 6x12 with 10K-12K GVWR. I thought that a deckover would be the solution for ground clearance issue but then I realized that could be another problem: high center of gravity. After doing some researching through some trailer manufacturers I noticed that some has low profile with the bed being a bit higher than mine (around 3" higher) and by photos some has pivot points closer to rear end of bed. I thought about the one that has ladder ramps that can be stored under the bed. So I think 2-in-1 trailer sound good to me, in case in future I want to haul equipment like skid steer. Thought it'd be better to buy bigger than what I need now and then later find out to be too small again.
I've looked at a few manufacturers like Bri-Mar and Cam Superline and am sure there are more of them. What do you have and what would you recommend? Thanks.
