jakeelee
hey guys,
i am waiting to pickup a brand new 5 ton dump trailer that i am planning to use for tree service - brush / chips / logs / stump grinder and i wanted to know if anyone could suggest some tips to keep if from rusting.
i live in canada so we get snow but i am planning to build a wooden chip box, undercoat annually, and park it in my garage for the winters, unless needed.
the trailer is zinc primer, powder coated, hot dipped, painted steel from the factory, i am not sure if the floor is painted/coated but it is 11 guage steel
any advice on using bedliners sprays and/or miracle paint on a new trailer.
i dont want to sand/grind it down and ruin a new trailer either
i was evening thinking to lay plywood to prevent knicks as i will be chainsawing inside the trailer but i dont know if that will cause rust issues also ie. moisture and stuff under the boards...
thanks in advance
thanks in advance
