dumbest mistakes
Blue Collar
Indiana
everyone at some time has done something stupid and right after you say to yourself, what was i thinking?
I was milling down a city street and milled right over a manhole that i painted out, was looking right at it, new it was there, and for some reason just spaced out and chewed it right up. Ha, i felt like an idiot.
Toegrinder
CO
Milling Foreman
After being in milling for 10 years now, I have always had a great deal of respect for these machines and the damage they could cause you if you got tangled up in one if you lost your concentration. well, last august I had my "blonde moment", got in a hurry and stuck my foot under the endslide/side plate to clear out material with the drum running...hence my username. spent a couple days in the hospital. Everyone has bad days and stupid mistakes, including me, that was just my worst and hopefully my last. It has definitely renewed my respect for mills.
andoman
midwest
worked with a company in Fort Wayne, Indiana that was lime stabilizing the ground and hit a 12 inch gas main, not a good day.
milling_drum
out west lately
asphalt mill operator (ret)
hmmm....theres so many....where to start...
While trying to get turned around in Providence RI, the third Wirtgen I had ever run back in 2002, I was always taught on 4 lane roads you do not need to tie up the whole road to turn. So I cut into the close lane of on comming traffic and backed up, I didn't take into consideration that the swing ratio on the conveyor of Wirtgen mills isnt very good, I clipped a utility pole and almost took it down.:O
I got a hard learning up there, some of the streets we were milling were less than 12ft wide, we had all trailer dump trucks to work with but we got through it:)
Heavy Highway
Texas
We've laid a Roadtec RX50 over on its side.....twice. /facepalm.
On one job I was running in a small town, a utility contractor had been through just before us and patched over a blow off valve. 20' geyser on Main St after the CMI hit it. Whoops.
bean
PR1000 - trying to figure out why the drum wouldn't engage for 15 minutes (the 3412 engine wasn't runing)
milling_drum
out west lately
Dumbest for sure...
Too run a milling machine ahead of a concrete widening/slab pour for I-385. It was horrible to use a mill to cut subgrade in dirt then bounce back to asphalt. Over and over and over....
D&GExcavating
Minnesota
We have a RayGo Gator with a 8V92 Detroit in it. It's really supposed to be a reclaimer for dirt but we put an asphalt drum under it and we've acutally been using it like that for 10 years. I haven't operated more than a couple hours on it so i can't say that i have any personal screw ups but the first guy we ever had operate it would always always always hit manholes. It seemed like every street he did he would take out a couple of them. And every time he would hit one it would snap both of the drive chains on the drum.
bean
I am reminded of a chip seal company chipping the wrong road by mistake, it was done before anyone from the county noticed. lol
The Tackman
Georgia USA
Paving Foreman in Atlanta
When I first started spraying tack in the early 90's. I was told to spray an area from here to there......Well the foreman never told me to stop at the bridge deck that was in the middle. Being a newbie I sprayed across the bridge deck.:pointhead
milling_drum
out west lately
So me and this fella are running a W2100 in North Scottsdale last friday, end of a 14 hour day he says too me "thanks for sticking around till the end today". I'm like WTF is this dudes problem? They put a machine on the lowboy without a washdown. I couldn't even being to list all the work that W2100 needs, half a day in the shop would get it to decent shape most likely.
So earlier this well trained Wirtgen operator cut right through the crown of the road at full width 200ft from a main intersection, dug a few holes 25ft ahead and behind of that screwup because he would forget to cut the switch back on after shutting it off. Turning around at one end of the job where the mouldboard had grabbed some dirt he won't even look in my direction and cuts the tracks HARD in the dirt making a mess of it....This is all on city streets work too...
It was kinda funny on that pull when he went into the crown at full width, The front track gets too the yellow line and I motion to cut the machine straight and go from there, He ignores me, I bring both sides up a little bit and walk over to the paving supt who is standing not far away and start to discuss how to fix the mouldboard digs into the dirt.....we have a 30 second convo and I see his eyes lighting up as he watches the path the mill is cutting...He starts running towards the mill with both fists in the air screaming STOPPP!!!! It was actually hilarious.
milling_drum
out west lately
Oops...
Last night coming into a 4 lane intersection with the belly dump squeezing over to aviod the cones I lost the painted skip line, so I stayed with the permanent white skip lines....when the truck pulled away I wound up 3 ft off the painted line....
I was king screw up last nite:)
Johnc
Toronto
setting down the drum of a 500 with both rear legs up well above the pavement- then engaging the drum- luckily nothing was behind me just a little scare.
milling_drum
out west lately
Years ago (1998 or 1999) when I was at the Miller Group in Atlanta, they had a Roadtec RX60 on rental from Roadtec because they had so much work. Being I was the only one with any Roadtec experience they made me run it more often then not. MIller were hardcore CMI people and swore they would NEVER lower themselves to Roadtec.
We were excavating on SR 19/41 just south of Atlanta by the speedway, I'm backing it up and loving the fact it has a rear steer lever mounted on the backside of the operators console so you really don't have to turn around much after you get the front tracks straight....except to watch the boom just miss a utility pole....oops....
But getting back to the beginning of the area being removed I get lined up while the groundman gets the water truck and pulls it up behind the machine. We load up with water and disconnect, walk towards the joint. lower the ass end to zero, flip switches.....why isn't it coming down? Without shutting the switches off I peek over the side and see one of the skis is jammed in the up position and while I'm looking at it...it lets go...before I can reach the auto's the machine just instantly falls to the ground. I'm on my @ss on the console being thrown around while its traveling backwards on the turning drum....missed the front of the rented water truck by less than a foot when the engine finally stalled/stopped. Groundman nearly had to go to the hospital from laffin so hard...I had to go change my pants.
daddy
usa
Thanks for sharing, milling drum. The truth will set you free! One of these days I might share my best screw up.
It's been years, but I'm still not too keen on telling the tale.
milling_drum
out west lately
Working for a big milling operation like that, it didn't even rate as a big deal too them. They wanted to get rid of that machine ASAP. After we ran the S@@T out of it pretty much all summer day and nite, Roadtec rented it out to East Coast Milling in Florida, they ran it 3 hours and the lower conveyor belt split right up the middle for a few feet.....That amused me very much:)
Come on Bro, tell us your sins hahaha....I've got PLENTY more too add when others fess up some more;)
bean
After milling from about 6pm to 6 am I drove to pickup our hydraulics field tech to help troubleshoot a pump that wasn't working on a recycler. I managed to change the rotation of our spare pump by about noon the next day and install it only to find out the POS still didn't work.... I had changed the wrong pump (there is 3 of the same model/size) the one i wanted was on the other side of the engine. Usually I am a bit sharper *** slept 2 hours and back for some more work :)
