Hi All, I'm just jumping into this forum for the first time. I recently bought an old Drott 40 BEC, SN is 693 so I think its late 70's early 80's. It has a Perkins T4.236 engine.
I started and ran it 3 or four times for short stints with no issues the engine sounded good and strong. then once I fired it up it ran for 1 minute or so, began chuging and now I cannot for the life of me get it to turn over...
before it died I was poking around the engine looking at stuff and I exersized the manual shutoff on the fuel pump and also pulled the pump arm on the highlift pump a couple times.. this is when the engine was off before i knew of any problems. Next was when I tried to start it and it ran fine for the 1 minute then quit.
since then I have replaced the battery and changed all the filters, cleaned the air filters, fresh engine oil, bled the air out of every port I can find on the fuel delivery and still it won't turn over. I have even tried a little cold start in the intake which gets the engine to fire for a half second and then nothing.
it seems to me like it is just not getting the fuel but i have loosened the high pressure lines at the atomizers and you can see the fuel leaking one at a time when i crank the engine..
Any thoughts? am I missing something obvious? seems odd that the fuel pump would just randomly stop producing enough pressure all of a sudden... or likewise all four atomizers fail all of sudden..
sorry for the novel!
