Drive Motor - Grinding/Squeling Noise?
NCPIPELINE
Raleigh, NC
The Fixer
2007 T190 H Pattern machine with 3000hrs. It started making a funny noise on right side, now the noise has shifted to the left side. Ideas? Final Drive?
Part sman
usa
Sound like you may have a problem with brake- causing your squealing. It is possible you have a bad seal on the brake piston on the right side. The left and right side brakes are released by a common supply, so if the seal on the right is not holding and dumping in the motor, the pressure to the left side will also be low causing a similiar noise.
crewchief888
NWI
check the case drain filter for debris.
check the hyd filter for gold flakes
you can also cap off the brake hose going to the motors, and see if the brakes hold.
you may have already done some damage..
:drinkup
NCPIPELINE
Raleigh, NC
The Fixer
Damage was definetly done, Right side drive motor housing failed, case drain FILLED with silver particles.
