Double Loading a tilt trailer
Discussion in 'Trailers' started by brickhead, Jan 30, 2016.
  1. brickhead
    brickhead Active Member
    May 9, 2015
    26
    pa
    Anyone add power to the cushion cylinders of their 20 ton tilt trailers to allow loading of 2 pieces of equipment?
  2. Shimmy1
    Shimmy1 Senior Member
    Aug 14, 2014
    2,778
    North Dakota
    I would be very skeptical of this working without destroying the trailer. I highly doubt the attachment of the cylinder would hold up to pulling forces, not to mention the size of the cushion cylinder isn't going to exert enough force to pick up much of a load on the back of the trailer.
  3. Jonas302
    Jonas302 Senior Member
    Jan 4, 2015
    629
    mn
    Maybe a ball valve in the hose of the cushion cylinder to keep it tipped until both pieces loaded of course still need the balance to untip another way would be to load off ramps or bank
  4. Pops52
    Pops52 Member
    Jan 20, 2016
    13
    part time lowbed driver "retired"
    Penn Valley, CA
    Thers 2 ways to do this. 1, load the first piece & stop just before it tilts. Load the 2nd piece as close to the 1st as possible. Move the 1st till the bed tilts, then lock the bed. Easier with 2 people. The other way is to load the 1st piece & stop just before it tilts, then block the bed from dropping then continue up til you have room for the second piece. I preferred the 1st method.
  5. bvfdfire
    bvfdfire Well-Known Member
    May 20, 2010
    165
    project superintendent for highway heavy construct
    east TX
    I've pulled two different Hyster trailers in the past that were tilt bed, they had float as well as power up and power down. It proved to be very effective when hauling motor graders because we had to put the front axle up on the neck and then power down the lower deck.
  6. brickhead
    May 9, 2015
    26
    pa
    Suprised no one has converted one to power tilt even if it meant using heavier cylinders. I like my 7ton tilt are 20ton tilts a thing of the past? Not a big fan of ramps.
  7. ericscher
    ericscher Well-Known Member
    Sep 12, 2014
    196
    Central Ohio
    I built my PJ with a hydraulic scissor lift and added wireless remotes.
    Usually if I am loading two things I load one at a time, strap it down tight and then re-tilt. I also have he decking with built in rubber, so it's higher traction.
  8. brickhead
    May 9, 2015
    26
    pa
    Found a trail king with a hydraulic power tilt factor installed. Thanks
