Does water / ice affect greased joints?
Discussion in 'Lubrication' started by emmett518, Dec 20, 2021.
  1. emmett518
    emmett518 Senior Member
    Mar 24, 2021
    740
    USA
    When I greased my backhoe in the summer after a rainstorm, sometimes water oozed out of the joint.
    What happens in the winter? We had a ton of rain, and then it froze. Can I still grease? How do I keep ice from cracking anything? Lumber prices are too high to build a pole barn yet.
  2. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    4,970
    Oklahoma
    If you grease often enough there shouldn't be any room for water to penetrate the area
    Kobelco ireland, mg2361 and Nige like this.
  3. Delmer
    Delmer Senior Member
    Jan 3, 2013
    7,868
    Ice and water won't do as much harm as dirt and grit. Ice won't hurt anything in any greased joint I can think of, at least any joint loose enough to let rain water run in.
    JPSouth likes this.
  4. ianjoub
    ianjoub Senior Member
    Jun 22, 2018
    1,044
    Homosassa, FL USA
    Grease after use while warm instead of before use?
    Aarons81 likes this.
  5. James Sorochan
    James Sorochan Senior Member
    Aug 1, 2020
    302
    x-water & sewer construction Now farmer.
    Lethbridge county, Alberta, Canada
    Agreed with all said above. If its cold, keep your grease gun and tubes in a warm spot and grease it after you've warmed up the pins from operating. If you are running all the time in winter you could use an EP-0 or EP-1 grease which will pump easier.
    Vetech63 likes this.
  6. Steve Frazier
    Steve Frazier Founder Staff Member
    Oct 30, 2003
    6,354
    LaGrangeville, N.Y.
    There isn't enough water getting in to cause damage when it freezes
    CM1995 likes this.
