Disc Harrow for Finishing
Greg in KY
Kentucky
This may not be the right place to post this but-
I am looking at agricultural style disc harrows to do finish work for sowing seed on small lawn projects.
Probably a 3 point lift, 6' disc on about a 35hp ag tractor.
Do I need smooth blades/coulters or do I need the notched style?
Thanks, Greg
dirty4fun
N. IL
I would say smooth also. I have used a steel tooth drag quite a few times to level and fill in the low spots. I had a drag made out of steel wheel bands, that was pretty easy to haul and worked good also.
atgreene
Sebago, Maine
I would recommend smooth, as well as perhaps a drag style rather than 3pth. The drag will follow contours better and won't break disks in tight turns. I have a couple chain pasture harrows that I use by hanging them from my bucket on the excavator and spinning in a circle. Does a nice job of leveling and smoothing. You will need something for a pasture harrow to smooth out behind the disk.
AT&SW
central Fl
equipment owner/operator
For finishing disk then drag spreading your seed in between will give you a nice finish.
stumpjumper83
Port Allegany, pa
Movin dirt
A neighbor has a reverse tine rototiller for his tractor and it does an awesome job, somehow it makes rocks disapear. I Imagine after disking you would need to run over it with a york, harley rake, or rockhound to prep for seed.
Greg in KY
Kentucky
Thanks for the replies,
I just sold a nice drag type disc because I could not get in tight places with it. It did a good job otherwise but was sorta aggravating to move locations.
I was pretty sure I would be better off with the smooth because I would not be in sod.
For a drag-
I use about a 10' length of 6' chain link fencing with a 4" I-beam spreader across the front. This works as well as anything and can be shortened by simply folding it over on itself or rolled up an thrown in a pickup for easy hauling.
My rock removal equipment is a 5 gallon bucket.
jrtraderny
New York
"My rock removal equipment is a 5 gallon bucket."
Always starts 1st pull.............................
jr
CAT D7 man
Kansas
I've got a 35HP Kubota with a 3-point disk. If you have clay soil, smooth discs won't penetrate satisfactorly. I have a 6' disk with notched discs on the front gang and smooth discs on the rear gang. I learned the hard way that LandPride is probably the only disk worth owning if you're tilling with a utility tractor without rear hydraulics.
Plan on making repetitive passes ie. back & forth, diagonally. It is almost impossible to avoid ridging. I have not succeded in 15 years of trying.
Larry
