John White
We bought a couple of acres inl the country a couple of years ago and built a new house. We noticed of a evening when the air was heavy we could smell gas. We had to close our bed room window at night it got so bad. Complained to the gas co. and they didnt seem intersted or worried. Said there were old abandoned wells and old lines in the area and would get a gas smell. Called the EPA and of course they werent interested. Called the fire dept. and they wouldnt investigate. About 6 months ago we had alot of rain and high water. I could see the water bubbling and could smell gas over the bubble. I called the gas co and finally they come out. Dug down and found a old active gas line. Found it was leaking in several places. Question is, when they used the backhoe to dig it out they did'nt seem at worried about a explosion. If there was a spark, wouldnt it set it off. I talked to a neighbor and he said on his farm, in places it is leaking so bad that it has killed the vegitation. Gas co says it would cost more to replace the lines that what it costs in loss of gas. I guess the people around here wont press the issue because the gas co says it is a old line installed in the 30's and with complying with all the regulatlions now to replace it, that they would just shut the gas line down. Leaving people with no gas. Again how do you dig around a gas line that is leaking without a risk of fire?
