deutz won't stay running
Discussion in 'Generators/Gensets' started by TRAVISB, Feb 15, 2018.
Tags:
  1. TRAVISB
    TRAVISB Member
    Feb 15, 2018
    14
    arizona
    i have a lincoln commander 500 with a deutz diesel model # F3L912 that will start just fine and run for 20 seconds then shut itself off. hit the start button and it fires right back up then dies after about 20 sec. anybody have any ideas? fuel is full, battery and alternator good.
  2. thepumpguysc
    thepumpguysc Senior Member
    Mar 18, 2010
    4,991
    Master Inj.Pump rebuilder
    Sunny South Carolina
    Does it have an electric shut-off solenoid gizmo in the fuel line going to the inj. pump..??
    They do have, or most of them have, safety devises that'll shut'm down if something not right..
    Oil pressure is the main one..
  3. thepumpguysc
    Mar 18, 2010
    4,991
    Do you have to press & hold a button while turning the key switch??
    IF SO, you have safety devises.
  4. Former Wrench
    Former Wrench Senior Member
    Jan 3, 2014
    355
    Road Construction Permit Analyst
    SE Alaska
    Not viewing the machine I can only guess so; does it have a low oil pressure switch? Look for any safety overrides that might be defective.
  5. thepumpguysc
    Mar 18, 2010
    4,991
    FW>> DONT YA KNOW??
    We're ALL supposed to know what they look like.. how they operate & which safety switches are bad..LOL
    How much oil they take & what kind, what injection pump it has on it & what the pump #'s are..
    .. & what the timing is.. & the torque on the rod bolts.. & valve clearances.. Lol
  6. TRAVISB
    TRAVISB Member
    Feb 15, 2018
    14
    arizona
    Yes it has the fuel solenoid. To start it, flip toggle to "on" and push button. On what I'm pretty certain is the oil pressure switch it has 2 wires to it. I started the machine and put both wires together (not on switch) to bypass it and it still dies. Im leaning toward the fuel solenoid being bad but not sure and dont know how to test it
  7. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,108
    There should also be a switch on the belt tensioner which could cause the problem. It shuts the engine down if the belt breaks.
  8. TRAVISB
    TRAVISB Member
    Feb 15, 2018
    14
    arizona
    Just 1 belt. Fan, crank and alternator. Alternator is the tensioner
  9. funwithfuel
    funwithfuel Senior Member
    Mar 7, 2017
    2,356
    Mechanic
    Will county Illinois
    Try running alternate source of fuel?
  10. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,108
    That's interesting. I don't think i've ever seen an air cooled Deutz without a spring tensioner on the fan belt.
  11. TRAVISB
    TRAVISB Member
    Feb 15, 2018
    14
    arizona
    Well if it's rare or obsolete you can bet I'm gunna have to deal with it.
  12. funwithfuel
    Mar 7, 2017
    2,356
    Mechanic
    I don't think I've ever seen one with a Spring loaded belt tensioner
  13. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,108
    F3L912.jpg Just to confirm we're all talking about the same engine?
  14. funwithfuel
    Mar 7, 2017
    2,356
    Mechanic
    That looks more hatz to me
  15. thepumpguysc
    Mar 18, 2010
    4,991
    You said, flip the toggle & push the button..
    The toggle is gonna be battery voltage & the button engages the starter??
    Do you HAVE TO HOLD DOWN a button before the engine will stay running..
    The ones w/ oil pressure sensors have a button you have to hold down until oil pressure is up, then release it..
    I'm kinda thinkin like Cmark.. "SOME" engines had a spring tensioner w/ a button on it that would shut the engine down if the timing belt got sloppy..
  16. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,108
  17. TRAVISB
    TRAVISB Member
    Feb 15, 2018
    14
    arizona
    Mot. Nr. 8602808
    Model F3L912
    Fam. YDZXL03.8016
    Cmark thats not the exact engine. and there is no button to hold down its just a push button start. in other words no key switch.
  18. thepumpguysc
    Mar 18, 2010
    4,991
    If you don't have to hold down a button, chances are there are no safety shut downs..
    The belt tensioner sensor, if equipped, WILL shut one down.. BUT it was an option on those engines..
    Yours might not have one.
    Now, back to the problem.. does it shut off like its electrical/quick or like fuel/chug chug chug..??
  19. TRAVISB
    TRAVISB Member
    Feb 15, 2018
    14
    arizona
    It's quick. If I flip switch on but don't start it, I can hear a "clunk" and then hear it again after about 20 seconds which is about how long it runs when i start it.
  20. TRAVISB
    TRAVISB Member
    Feb 15, 2018
    14
    arizona
    The clunk is coming out of the fuel pump
