Peter Webster
pump 4? Well i cant be 100% sure, but I have lined it up pretty carefully and there is fuel spurting. The other pumps arent pumping like 4 is, so i assume 4 is engaged.Are you 100% sure the pin is engaged in the rack.
The solenoid is out and was always out, as it was the first thing i thought of.
The control rack moves freely to the left then springs back when i push on it thru the solenoid hole.
I will try with the injectors out again and see if the pumps work any better. I am also waiting for the new fuel pump from germany.
Any tips for ensuring the pin is engaged?
Once again thanks to you both for your help
