Nay125
H All, In a bit of a pickle here and in need of some urgent advice if anyone can help please!
I have a Deutz 1011 engine in a Dumper (F3L 1011 L) that came to me for a service but had a running fault so was starting and running but with no revs. I completed the service, the customer then also asked me to do a timing belt change which i did and then started the dumper which was starting and idling as it was when it came to me. I replaced the diesel lift pump and was still starting and idling as it was before.
I then decided to look into this running fault it had and so removed one of the fuel injector pumps to have a look. Bearing in mind i wasn't aware that these were timed i then removed all three pumps to have a look for anything obvious. After seeing that one looked a little loose on turning i refitted all three into the same place that they were before however am not certain on which position the fuel control lever was in when they came out of the engine. Now when i start the engine up, it goes straight into runaway and won't shut off with the key and the only way i could stop it was to cover the inlet hole with my hand to kill the engine.
I have removed and refitted these injector pumps several times today trying different positions and different ports, and i believe i have it timed right however am not 100% sure that i have BDC right as i'm unsure on how is the most accurate way to do this other than by feel? The fuel rail is moving freely side to side and so i am pretty certain this is not bent.
i have removed the injectors from the top of the engine and the fuel rail to check if they are all pumping and when trying to start all three pumps are squirting diesel however when they are removed from the engine and i put pressure on the spring on the workbench only two of the three actually squirt diesel through the top as the other one (the one that was removed first that looked loose) is not pulling diesel through the top but seems to be going backwards and squirting out of where the banjo bolt fits. Could this mean that this injector pump needs changing?
Is there any other testing that you could suggest please? I've exhausted all of my options and hoping that you or someone on here can help
Thanks in advance!
Thanks in advance!
