Don't fiddle with any adjustments if you don't have a timing tool. You can remove the units (one at a time) and just hold it in your hand, push the rack in and out, sqirt some WD 40 in and jiggle. Sticking problems are generally caused by water in the fuel. I was called to a machine that had sat over a weekend and one unit was jammed as tight as. It had to be replaced.
