Detroit 2-stoke Diesels - fuel tank sediment buildup?
Discussion in 'General Industry Questions' started by OFF, Mar 14, 2019.
  1. OFF
    OFF Senior Member
    Sep 30, 2009
    714
    HD Mechanic/Shop Foreman
    Alberta, Canada
    I look after several Detroit 71 and 92 series diesel engines in stationary emergency stand-by service. They had been having injector problems which lead to fuel samples being taken. The samples were bad, which lead to discovering huge sediment (mud) buildups on the bottom of the fuel tanks. Engines are in heated indoor spaces and so are the fuel tanks.
    Is this just partials dropping out of the fuel over time? How much of it could be picked up from the engine fuel system and returned to the tank by the fuel return line? Has anyone ever heard of adding some sort of filter to the fuel return line?
    These engine do way more sitting than they do running, so the fuel does get old. Is diesel that dirty?
    Opinions and ideas welcome.
  2. Nige
    Nige Senior Member
    10,333
    IMHO fuel tanks of engines that run infrequently are more at risk of accumulating sediment than tanks on equipment that gets refuelled every day.
    Keeping the tank full will reduce, but not totally eliminate, the accumaltion of water due to condensation.
    Most maintenance plans for standby gensets recommend that the tank be drained of any accumulated water and sediment on a weekly basis. The illustration below is from a Cat maintenance manual, but I can't see a DDA Manual recommendations being majorly different.
    You had the fuel that was in the tanks analyzed, but did anyone take samples of the fuel that is being put into them from the fuel supplier..?
    Also has anyone analyzed the fuel for the presence of algae..?
    OFF likes this.
  3. Birken Vogt
    Birken Vogt Charter Member
    Nov 30, 2003
    2,490
    Grass Valley, Ca
    It sounds to me like what is needed is to do whatever it takes to remove the sediment, and then hire a fuel polishing service on a regular basis to ensure it does not happen any more.
  4. OFF
    OFF Senior Member
    Sep 30, 2009
    714
    Alberta, Canada
    No, we've never sampled the fuel from our suppliers truck, but I think I'll go do that just sh1ts & giggles. We're talking 30 years worth of accumulation here. Water levels in the fuel samples were very low, it was just the particulates that killed us. It was an amazing amount of mud, some of it magnetic, most of it not. We have our own fuel delivery truck, and I can see right to bottom of the tank with the help of a light, there's no sediment in the truck. But it's refilled 3 times a week as a average, so the fuel doesn't sit long enough to fall out.
    We never sampled fuel until it became an injector warranty issue. And unless there is a breakdown, we only touch these engines once a year. I'll have to approach the owners about stepping up their PM program. Fuel polishing is a good idea. Wouldn't be hard to set up a filter cart and run it through once in a while.
  5. Nige
    Nige Senior Member
    10,333
    Making your own filter cart to suck the sediment out of the bottom of the tank shouldn't be hard. A couple of large-capacity 2-micron (or better) filter heads, some hoses and a pump, and away you go. My only other thought would be to suggest that you ask yourself is it easier to drop the sediment out of the hole in the bottom of the tank (I'm assuming they have one, and if not why not..?) or fabricate something to suck it out through the hole in the top..? The problem with sucking it out the top is that unless you get really creative with the suction end you only get what's directly below the filler neck, unless you do a complete vacuum drainage, flush, and refill after filtering. To equip yourself to do that is probably gonna cost a few $$, but either way I guess it would probably be cheaper than replacement injectors.
    OFF likes this.
  6. td25c
    td25c Senior Member
    Feb 15, 2009
    4,932
    indiana
    Out of curiosity , what are they finding wrong with the injectors ?
    Detroit Diesel will have primary & secondary fuel filters . Pretty good setup that will work under some nasty fuel conditions .
    If anything would think the primary filter would plug up & starve the engine of fuel .
    Had a similar issue with one of the cranes . I ended up draining the tank and power washed it out sticking the wand in through the filler cap and fuel sender port .
    Odd part was first symptom was an engine miss .
    http://www.heavytruckforums.com/showthread.php?51-Fwd-Trucks&p=3973&viewfull=1#post3973
    RZucker and Tenwheeler like this.
  7. Tenwheeler
    Tenwheeler Senior Member
    Dec 16, 2016
    339
    Georgia
    Did about the same thing on a 40 year old truck and some Ag equipment. How did this stuff that looks like mud show up? I thank there maybe something to this new fuel.
    Here say is it can have 1 or 2 percent ethanol without out even being labeled. Just enough to break down contaminants from the refinery to your own tank.
    I do not know but I have never seen anything like this before the last couple of years.
    OFF and td25c like this.
  8. OFF
    OFF Senior Member
    Sep 30, 2009
    714
    Alberta, Canada
    The original problem was bad oil samples, fuel showing up in the oil. We changed injectors and the rebuilts started leaking too almost right away. I had the dealer send out a tech to have look and the first thing he wanted was a fuel sample. It went from there. The engines were running just fine. These engine all have normal "larger size" primary & secondary filters plus a Racor as a first line of defense. Our fuel may have been nasty, but I don't think it was dirty, at least not after running through three filters.
    RZucker and td25c like this.
  9. td25c
    td25c Senior Member
    Feb 15, 2009
    4,932
    indiana
    Sounds like you got it covered with the fuel filters .
    Did they leak bad enough to raise the oil level in the pan or notice a drop in oil pressure ?
  10. Nige
    Nige Senior Member
    10,333
    As the young lady once said - "size isn't everything". Do you have any idea what micron rating are the elements..? Worst possible scenario is that you have something in there that will only trap particles the size of children, tree branches, & small dogs ..........
    mg2361 likes this.
  11. OFF
    OFF Senior Member
    Sep 30, 2009
    714
    Alberta, Canada
    Oil level only increased slightly, but it was enough to make the samples go south in a big way. No noticeably drop in oil pressure.
    td25c likes this.
  12. OFF
    OFF Senior Member
    Sep 30, 2009
    714
    Alberta, Canada
    Baldwin BF5800 & BF5810, not sure what the micron rating is on them. Racor was 10 micron, the dealer had us switch to 4 micron instead.
  13. RZucker
    RZucker Senior Member
    Jul 7, 2013
    2,410
    Mechanic/welder
    Wherever I end up
    Having a tiny amount of 2 stroke Detroit experience, It sounds to me more like suspended water getting through the filters. And water is far worse than fine dirt in those unit injectors IMO.
    Saw the results of a 12V71 trying to digest water in the fuel that ended up with 2 torched pistons after the injectors started dribbling.
    td25c and Mother Deuce like this.
  14. td25c
    td25c Senior Member
    Feb 15, 2009
    4,932
    indiana
    Something else to look close at is the fuel crossover lines & fittings in the head if you haven't already .
    A lot of places for fuel to leak internally .
    Tenwheeler likes this.
  15. Dave Neubert
    Dave Neubert Senior Member
    Jul 19, 2018
    318
    Monroe NC
    Sounds like rust from condensation in the tank may be best to replace tank if you don't have good access to the inside for cleaning
  16. John C.
    John C. Senior Member
    Jun 12, 2007
    5,611
    In civilian life I've seen a lot more leaking cross over injector tubes than leaking injectors. If you put a leaking injector on a pop tester and hold pressure to just below pop off you will see fuel dribble from the tip if it is leaking. As far as mud in the tank I would suggest draining some of it into a clear glass jar and take a photo to show your supplier. The distributors and oil companies don't like bad press about what they supply and will likely work with you about what to do.
    DMiller likes this.
  17. Nige
    Nige Senior Member
    10,333
    Can you get hold of better quality filters than Baldwin..? I'd class them on a par with Fram and Parts Store own-brand filters TBH.
    The spec sheet for the Baldwin filters does not include the micron rating which always gets me twitchy. So unless they are something super-special, which I doubt, they are nowhere near 4 microns. The Donaldson equivalents are P556915 (25 micron) for BF5800 and PF556916 (9 micron) for BF5810.
    Back to my earlier comment about removing nothing smaller than children, tree branches, and small dogs ...............
  18. kshansen
    kshansen Senior Member
    Mar 11, 2012
    6,213
    Central New York, USA
    Not knowing the exact application for these engines I'm wondering if the fuel tank is too large for the application. Just thinking that maybe if a smaller tank was used the fuel would not be sitting for as long a time.
    Moisture from condensation can cause nasty stuff to grow in fuel and that along with rusting of the tank can cause many problems. And like someone above said a full tank will have less condensation. So if the tank is so big it will last a year or more that would not be a good thing.
    Then again if this is in a remote area where getting fuel delivered is a problem you just have to do what you can to keep it clean. I'd be contacting the fuel supplier for suggestions from them on special treatments like a biocide. Such as:
    https://powerservice.com/psp_product/bio-kleen-diesel-fuel-biocide/
  19. boaterri
    boaterri Well-Known Member
    Oct 8, 2008
    103
    Television Engineer
    Florida, USA
    Howe's Diesel Treatment also works very well with DD 2 strokes.
    Rick
  20. td25c
    td25c Senior Member
    Feb 15, 2009
    4,932
    indiana
    Another random thought from a Detroit Diesel operator . :)
    I can understand sending an oil sample off and they found traces of diesel in the oil .
    These engines will weep a little fuel internal over time . It's the nature of the beast so to speak .
    Generally change the oil every 100 hours of use or if I notice a drop in oil pressure before hand .
    Detroit Diesel at 180 F temp showing 5 PSI oil pressure at idle indicates fuel in the oil . Time to change the oil & locate the problem given the time frame on the oil change .
    Only got one Detroit that don't leak fuel under the valve covers .:D
