Def Issues
ahart
Indiana
Attached is the procedure for flushing the DEF system.
  • DEF flush.pdf
DEF injector open circuit or short to ground. See Table 2 of the attached troubleshooting procedure.
272D2 (BL200773) with code 3361-5
So I followed the above procedure and see 100 Ohms for the DEF injector (at harness plug into DCU)
Simple question:
Where is the injector (I know it is in the back near muffler) Seems like the whole radiator needs to come out (I was only able to tilt it up a few inches at the back)..hopefully it's not the case?
And why is that injector failing and so expensive? I was told by field technician that DCU and pump might be bad too (not getting errors from these but these might come later after I replace the injector?)
Coaldust
Subarctic Backwoods Trailer Park
Big trucks is what I know. HAZMAT is what I tow.
Why is that injector so expensive?
Oh’ boy. Why does a Freightliner One-Box cost $10k with a six week lead time? Why did it take two years wait time for a KW NOx sensor?
Joe Dirt’s Dad had the best answer to this question.
ahart
Indiana
Post the serial number. I’m dealing with same code right now on a 420F2. Need to check the resistance on the injector itself. Also, do you have Cat ET?
Yes I am aware of the need to test the resistance, just trying to find how to get to it (probably easier on your backhoe) 272D2 skid
BTW I have a 2014 420F IT backhoe ...glad it does not have DEF!
ozarkag
ozarks
It's a long reach but possible without removing the radiator.
Removing radiator assembly would of course give much better access.
We have one in shop right now that the Injector had 3 ohms instead of 7. Did get it it out without removing rad, but isn't super easy.
Did changing the Injector clear the error? My technician thinks my DCU and Pump might be bad even if I have a single error (dosing unit)
ozarkag
ozarks
Don't have the new one in yet. I'll try to post back once we do.
Not sure why your tech would suspect other parts, unless he's unsure of his diagnosis, or trying to sell more parts.
ahart
Indiana
The unit I was working on was very odd, injector ohmed out at 7 ohms, book says spec is 6-8 ohms. Moved on to bypass wiring harness by making a new one, still have fault code. Tried a known good DCU and still had fault code. Ended up changing the injector even though it was in spec and it solved the problem. Can’t explain it, 7 ohms should have made it happy but for some reason, it was showing current above normal. I do know that driver in the DCU is a very sensitive circuit.
