mg2361
What are the "voltage" measurements of the M12 and M13 wires with the key on and issue happening? Check the voltage measurements of your ground wires for the TCU (terminals 1 and 2) and the Monitor (terminal K) as well. They should be less than 0.100 V. I also attached a solution I found. Not your serial number but worth mentioning.
Hear is the diagnostics out of the manual (won't be much help):
F1653 No CCU Transmit
Wire M12 (Purple) Harness (W3) Open
Load Center Harness (W3)—M12 (Purple) Open (Check/Repair.)
Wire M13 (Purple) Harness (W3) Open
Load Center Harness (W3)—M13 (Purple) Open (Check/Repair.)
CCU (A2) CCU (Replace)
MDU (Reconfigure). See Monitor Display Unit Reconfiguration Access Service Menu
, Machine Model (S 01) , Tire Size (S 03) , Enable Options (S 06) , and Delete Service Codes in Group 9015—15.
F1655 No TCU CAN Transmit
Load Center Harness (W3) M12 (Purple) Open (Check/Repair.)
Load Center Harness (W3) M13 (Purple) Open (Check/Repair.)
Wire R02 (Black) Harness (W3) Open
Load Center Harness (W3) R02 (Black) Open (Check/Repair.)
TCU (A3) TCU (Replace)
