CrossDrilledPiston
Hello everyone, hope your well. Not often that I use a forums for help, hate wasting the time of others on my problems.
But it's becoming desperado at this point and I could definitely use the help of this all knowing community.
The machine in question is deere 450clc with their all glorious 12.5/6125 ht 001/ powertec engine. Currently no mater what I try or replace I cant seem to get rid of trouble codes 636.10 cam position input pattern error and 637.7 cam/crank out of sync.
Due to this the machine, (once coolant reaches operating temp) will send heavy white plumes of raw diesel vapour out. I'm assuming this is due to pilot injection being shut off by the ecm.
Currently there has been significant work performed on this machine in order to determine the issue. Initially we were told by deere that the cam shaft was faulty on this machine. Wouldn't start, smokey and ran like dirt. So it sat there for a couple years. Eventually we got a donor cam from another 450clc. Performed the swap, and it started up with out skipping a beat. With in a few minutes of running, smoke and surging. Checked the fuel and lines made shure no air and installed a clear line on return to wach for bubbles. All air removed from system and with fresh fuel issue persists.
Called in deere they diagnosed a faulty ecm and wire harness, due to the same codes being thrown. Replaced ECM, wire harness, Cam sensor and crank sensor. Still no resolution.
Pulled the injectors out and sent them out to a reputable rebuilder, all of them were in need of rebuilding. At the same time we pulled the head and donor cam and sent it out to a machine shop to have new sleeves, cam bushings, installed, valves checked over and cam ground down, head checked out okay, with no issues found. Reassemble the machine, and the problem still persists.
Finally to eliminate that the cam shaft is not the true issue, we purchased and installed a new cam shaft. And to our surprise the issue is still ongoing.
Interestingly though when the 450 is put under load or worked the smoke immediately clears and it runs smooth but high or low idle result In plumes of smoke.
The turbo has also been replaced early on due to oil on the compressor side.
What I'm wonder right now Is, if there is a diffrent timing pin used for timing of the engine and another for setting valve lash. ?
Inspecting the cut slot on the crank shaft for the timing pin, I found quite a bit of bur from rocking the crank to fit the pin in. Would it be possible to create enough slop in the slot to throw the timing of?
Any ideas and help would be tremendously appreciated.
Thanks!
Thanks!
