Deere 4045 Engine Exhaust Slip Fit Leaking
Discussion in 'General Industry Questions' started by Birken Vogt, Nov 4, 2021.
  1. Birken Vogt
    Birken Vogt Charter Member
    Nov 30, 2003
    3,838
    Grass Valley, Ca
    Got this 4045HF270 in the shop with an adapter off the turbo outlet that fits inside the female part of this upturned elbow. It leaks a lot of exhaust out the joint. I think there might be some kind of a piston ring type deal in here. I am wondering what parts go bad on these and how to likely repair. I can't take it apart just yet because we still need it running for other problems but would like to know what to expect in here. What parts go bad in a setup like this. The v-band clamps seem to be holding fine. This fitting is more like what you would see on a long exhaust manifold, but a lot bigger.
  2. heymccall
    heymccall Senior Member
    Feb 20, 2007
    3,349
    White Oak, Pa
    Double check model number.
    I dont see HF270 in my sources.
  3. Birken Vogt
    Nov 30, 2003
    3,838
    Grass Valley, Ca
    Right you are
    4045TF270
  4. Tones
    Tones Senior Member
    Mar 15, 2009
    2,105
    Ubique
    HF275.
  5. mg2361
    mg2361 Senior Member
    Jul 5, 2016
    3,133
    Equipment Mechanic/Technician
    Pennsylvania
    No seal ring. It is a "rolled" end to the tube that fits into the elbow. A flange with no gasket at the turbo. Probably a rotted out tube. Serial number?
    Edit: I just saw your other post. PE4045T623558 When looking up parts by serial number the option code for that exhaust is 6401.
    Vetech63, Paul Council and DB2 like this.
  6. nowing75
    nowing75 Senior Member
    Aug 5, 2009
    773
    coatesville indiana
    just had that problem on our trencher same motor. I ended up replacing the short pipe and the elbow
  7. MarshallPowerGen
    MarshallPowerGen Senior Member
    Nov 27, 2017
    297
    Generator & Equipment Mechanic
    Coeur d'Alene, Idaho
    Had decent luck with cleaning parts and if not too rotten using some of the copper coat gasket paste to seal leaky exhaust sections.
  8. heymccall
    Feb 20, 2007
    3,349
    White Oak, Pa
    Cat recommens the 2P2333 high temperature sealer on exhaust connections that are essentially slip fit, like the 3116 3 piece exhaust manifold.
    DB2 likes this.
  9. JLarson
    JLarson Senior Member
    Aug 23, 2020
    484
    AZ
    Even on new ones sometimes the casting job is so **** poor you have to goop em anyway lol
  10. treemuncher
    treemuncher Senior Member
    Dec 31, 2006
    410
    eatin' trees, poopin' chips
    West TN
    I use JD's Power Assist app on my phone & tablet. Enter the engine serial number and the factory build options are at your finger tips with all of the part numbers you need. Makes life easier, for sure.
    MarshallPowerGen and DB2 like this.
  11. Birken Vogt
    Nov 30, 2003
    3,838
    Grass Valley, Ca
    I got the parts in and the new item #2 is a looser fit in the item #3 than the original leaker was.
    I have JD starting a "case" now but we will see if they even care.
    What kind of goop do you recommend? I once used some white ceramic paste that came in a toothpaste tube and hardened into ceramic.
  12. JLarson
    Aug 23, 2020
    484
    AZ
    Permatex has 80335, a 2000 degree goop, loctite has MR2000 too. Loctite is what cat sells as their sealer usually.
