PeteG
Hi,
We have a Deere 244J loader serial 711681 having issues with the loader hydraulics. The boom, tilt and aux 3 and 4 functions all stutter. The loader was running perfectly today for 4-5 hours and it just started. You can work the functions back and forth and they slowly get better, but as one function gets better, another gets worse. And when you increase engine speed, the hydraulics “lock up” for lack of a better term, and the function you are using stops. The stuttering only happens at idle, and the hydraulics only seem to work while at idle when the issue is present. Also, the hydraulics lines move significantly when the stuttering takes place, especially watching from the valve under the loader arms.
I thought it seemed like air in the lines, and we loosened pretty much all the lines under the front cover at the main valve assembly and cylinders with no change in results. The loader drives very smooth, so it’s within the loader hydraulics I believe. There are also 2 accumulators under the front cover. One I know is for ride control, but there was another that I wasn’t sure if that could be the cause of the problems if it was leaking air into the system, but not sure on that. When looking at the hydraulic level, the oil isn’t foaming of milky either so I don’t think the pump is cavitating. The float/return to dig and ride control haven’t worked for years on this, but I thought I would mention that in case it could cause issues. Not sure where else to look besides the pump pressures, so any help definitely appreciated. Thanks.
