Deere 200clc heater blows cold
Discussion in 'Excavators' started by Oliver182, Jan 2, 2017.
  1. Oliver182
    Oliver182 Well-Known Member
    Dec 18, 2008
    85
    Iowa
    Have a 06 Deere 200c that the heater has been blowing cold all fall/winter. Have both coolant valves open and can try different settings on control panel and does no good. AC works good in summer. Any ideas ?
  2. Bumpsteer
    Bumpsteer Senior Member
    Sep 2, 2009
    1,152
    Mechanical designer
    Front seat on the Struggle Bus
    Backflush the heater core. Just make sure your flushing the opposite direction of the coolant flow.
    Also, blow out the fins on the heater core, I've seen them so packed with dust/dirt they look like a brick.
    Ed
  3. zx240lc-3
    zx240lc-3 Member
    Sep 22, 2016
    16
    verify everything on your heater control is working. I've had issues with some of the buttons not working on the older C model machines. Maybe its not switching your vents properly and pulling outside air?
    Also check on the heater core that the valve that controls coolant flow is opening and closing.
    http://jdpc.deere.com/pimages/TX10/TX1006706______UN21APR06.gif
    AIR CONDITIONER AND HEATER COMPONENTS
    Cart key PART NO. PART NAME QTY SERIAL NO. REMARKS
    0 4609049 Air Conditioner 1 (SUB FOR TH4450707, 4450707, TH44260 47 OR 4426047 ) (ALSO ORDER 4464479)
    1 4464341 Case 1 (SUB FOR TH4464341)
    2 4464342 Case 1 (SUB FOR TH4464342)
    3 4464343 Case 1 (SUB FOR TH4464343)
    4 ...... Case 1 ( 4464344 NLA) (SUB FOR TH4464344)
    4A 4464345 Case 1
    4B 4464346 Lining 1
    5 4464347 Case 1 (SUB FOR TH4464347)
    6 4464349 Case 1 (SUB FOR TH4464349)
    7 4464350 Case 1 (SUB FOR TH4464350)
    8 4464352 Evaporator 1 (SUB FOR TH4464352)
    8A 4464353 Evaporator 1
    8B 4464354 Flow Control Hyd. Valve 1 (SUB FOR TH4464354)
    8C 4464355 Bolt 2 (SUB FOR TH4464355)
    8D 4370249 O-Ring 2
    8E 4464356 Cap 1 (SUB FOR TH4464356)
    8F ...... Isolator 1 TH4464357 NLA)
    8G ...... Plate 1 TH4464274 NLA)
    9 4464275 Heater 1 (SUB FOR TH4464275)
    10 4464276 Electric Motor 1 - XXXXXX Machines Built Before November 2005 With Pigtail Harness (USE WITH 4610412) (SUB FO R TH4464276 ) (USE WITH TH4450707, 4450707 , TH4426047 OR 4426047) (USE WITH 4464479)
    4370266 Electric Motor 1 XXXXXX - Machines Built November 2005 and After Wi thout Pigtail Harness (USE WITHOUT 4610412 ) (USE WITH 4609049) (USE WITHOUT 4464479)
    11 4464277 Switch 1 (SUB FOR TH4464277)
    12 4464278 Resistor 1 (SUB FOR TH4464278)
    13 4464279 Transistor 1 (SUB FOR TH4464279)
    14 4370269 Relay 3
    15 4464280 Sensor 1 (SUB FOR TH4464280)
    16 4448925 Sensor 1 (SUB FOR TH4448925)
    17 4464281 Electric Motor 1 (SUB FOR TH4464281)
    18 4464282 Electric Motor 1 (SUB FOR TH4464282)
    19 4464283 Electric Motor 1 (SUB FOR TH4464283)
    20 4464284 Lever 4 (SUB FOR TH4464284)
    21 4464285 Lever 1 (SUB FOR TH4464285)
    22 4464286 Lever 1 (SUB FOR TH4464286)
    23 4464287 Lever 1 (SUB FOR TH4464287)
    24 4464288 Lever 1 (SUB FOR TH4464288)
    25 4464450 Lever 3 (SUB FOR TH4464450)
    26 4464451 Door 1 (SUB FOR TH4464451)
    27 4464452 Door 1 (SUB FOR TH4464452)
    28 4464453 Door 1 (SUB FOR TH4464453)
    29 4464454 Door 1 (SUB FOR TH4464454)
    30 4464455 Door 1 (SUB FOR TH4464455)
    31 4464456 Door 1 (SUB FOR TH4464456)
    32 4464457 Rod 1 (SUB FOR TH4464457)
    33 4464458 Rod 1 (SUB FOR TH4464458)
    34 4464459 Rod 2 (SUB FOR TH4464459)
    35 4464460 Rod 1 (SUB FOR TH4464460)
    36 4464461 Rod 1 (SUB FOR TH4464461)
    37 4464462 Rod 1 (SUB FOR TH4464462)
    38 4464463 Rod 1 (SUB FOR TH4464463)
    39 4370296 Bracket 2
    40 4464465 Bracket 2 (SUB FOR TH4464465)
    41 4464466 Bracket 2 (SUB FOR TH4464466)
    42 4464473 Hose 1 (SUB FOR TH4464473)
    43 4370267 Isolator 3 (SUB FOR AT214213)
    44 4464474 Seal 1 (SUB FOR TH4464474)
    45 4464475 Isolator 2 (SUB FOR TH4464475)
    46 4370299 Washer 3 (SUB FOR AT214245)
    47 4464476 Washer 1 (SUB FOR TH4464476)
    48 4370298 Washer 1
    49 4464477 Clip 7 (SUB FOR TH4464477)
    50 4464478 Clip 12 (SUB FOR TH4464478)
    52 4464479 Wiring Harness 1 - XXXXXX Machines Built Before November 2005 (N LA) (ORDER 4610412) (SUB FOR TH4464479)
    4610412 Wiring Harness 1 XXXXXX - Machines Built November 2005 and After
    53 4370308 Screw 9
    54 4464480 Screw 5 (SUB FOR TH4464480)
    55 4370309 Screw 17
    56 4464483 Screw 32 (SUB FOR TH4464483)
  4. ATCme
    ATCme Well-Known Member
    Aug 24, 2015
    113
    bc
    At 12,000 hours my 270 had a clogged core. Easy fix.
  5. Delmer
    Delmer Senior Member
    Jan 3, 2013
    7,565
    If both heater hoses are hot, then the coolant is circulating and the air is blocked. One or both hoses not hot, then the coolant isn't circulating. That will get you pointed in the right direction.
