wastednights
Looking for some information, I have a Daedong/Kioti DK50SE that has an oil leak from the bottom of the transmission.
I have searched for information, but cannot find much, I'm hoping someone has some experience with these?
There is an open hole in the bottom of the transmission case, between the flywheel housing and the main transmission, the MFWA shaft passes through the flywheel housing and through this "intermediate" case. The oil does not leak in the following situations:
Tractor is switched off
Tractor is running
Tractor FEL is operated
It only leaks when the machine is driven, I'm thinking it has to be a seal on the MFWA drive shaft at the transmission end.
I found an online parts listing for Daedong on an Australian site, but cannot locate a DK50SE.
Also if someone has pulled one of these down, an indication of repair time would be great.
Thanks in advance
Tractor is running
Thanks in advance
