D8t transmission filter screen
nicky 68a
england
I’ve seen worse Franklin,much worse.
Looks ok without close up glasses on job.
The pleats are black from new and you often see the odd flake of metal in there
Franklin7
Naches wa
There seemed like there was quite a bit of black gritty material in the creases of the pleats to me. And pretty metallic looking. Yes probably harder to see in the pictures posted. They're shouldn't really be none unless one of the clutches is starting to go right?
Franklin7
Naches wa
Machine has still been working. 1st gear seems as if it's getting worse with the sporadic stops. Been using it in 2nd gear and working fine just pushing garbage off a slope with no real hard pushing. I think I might have to pull the transmission.
