that's it Nige it is similar to the G and H series graders and uses the same procedure to bleed the signal line
Looking at the ops picture he has the allen key in the wrong fitting. The bleed screw will be underneath the signal hose. the hose will need to be loosened and moved out of the way
Mark
Due to the age of the machine the pump or compensator has probably been up dated and in that case is self bleeding
tell us more about what happened for the simple resolver test
Did the lift feel like normal when you operated the tilt control?
Go back to one of my previous posts regarding your oil analysis results stating it was unusual for a machine to have SAE30 oil in the hydraulic system, especially one that came from somewhere up North. Was the previous owner masking an existing problem by putting a higher viscosity oil in the hydraulic system and you exposed the problem when you switched to SAE10W30 oil..?Looks like I need to have the control valve rebuilt and if that doesn't do it have the pump replaced. Must have been a coincidence that it happened right when I changed the hydraulic oil
10W, yes. I haven't read the whole thread, but you said in post #173 he put 10W30 in, and 10W30 is a bunch thicker than 10W, in my experience.An SAE 30 oil is approximately 2.5 times the viscosity of a 10W when cold. It may make a difference.
