I understand where you're going with this, but here's my 2c.
The screen should go back into the converter suction as soon as practical, but at the same time I would also be looking at where contamination could be entering the transmission/converter hydraulic system. You remember that we spoke about the breather for the power train system earlier (9G-5127 - Post #36 on Page 2). I would replace that, make sure that locations such as the power train oil filler cap and the dipstick were not letting dirt in, etc. I'd do all that before even thinking about changing the oil again. I would do all the other stuff to make sure that nothing could get into the transmission oil system that shouldn't be there. If you can't keep contamination out what's the point of changing the oil..? I recall that you reconnected the wires on the transmission filter housing. Is it still throwing warnings for plugged filters..? If changing the filter makes the light go out, keep changing them, it means that the filter is pulling contamination out of the system IMHO.
For the hydraulic oil I would replace the 191-5439 breaker relief valve on the hydraulic tank (again, dirt can get in there) sample the oil and change the filter every 250 hours, and see how the oil analysis goes.
One of the most important factors to consider when you send off oil samples is to make sure that all the necessary information is completed on the form that accompanies the oil sample. Without that info any lab would be struggling to make a good interpretation of the analysis: -
1. Oil changed - Y/N.?
2. Filter changed - Y/N.?
3. Operating Hours on oil..?
4. Approx. quantity of oil added since the last sample was taken.
