d8h to d8k blade
tj_farmer
IL
will a blade off a 8k fit on a 8h with no issues? its a su blade.
DPete
Central Ca.
Check the rod ends, the late K's I had clamped on a ball welded to the back of the dozer, some H's had a pin to attach the rod to the dozer.
tctractors
Worc U.K.
Just thought I would say D8H blade has 2 x10 bolt cutting edges D8K has 3x7 bolt edges, the later the K blade the better they cut, as they did adjust the edge angle for better finish, oh and a K blade is a nice bit higher, saves having to go back to collect the bit of muck that fell off.
tctractors
