Hotwheels81
Got given a antique D8-2U cable dozer in wonderfully complete and semi straight condition
I can get the pup motor running fine and it still spin's the big 6 diesel but have no luck getting fuel to the injectors, it builds pressure on the fuel pump gauge (and yes there is fuel to the filter housing and the filter "looks" ok) but it does not make it to the injectors... even had the injectors out of the head and dumped a bit of fuel into the holes and when i spun it over again it fired rite away... i pulled one then two then three injector lines off of the pump while cranking and no fuel came out... :Banghead
im thinking there is something i am missing, aside from the decompression lever and the hand throttle there are no other linkages i can see that would kick the pump on? maybe somewhere along the trail a previous owner/op chopped another control rod off? :beatsme
would be nice to see this old beast run so any help or pictures would be greatly appreciated!
