D7E Serial Number - Specs
cgfreeland
Texas
Anybody have any source info on specs on a d7e serial number 48a479*? I need to know if its the 160hp or 180 hp and what the weight is, the year it was made, I am having trouble finding any info on the net. Thanks
Greg
Wi
Excavating Contractor
More than likely you mean 48A4790 through 4799. That would make it a 160 HP and it would have been built in 1964 or 1965. Weight with a blade is about 44,000 Pounds.
Terriffic machine. One of the great ones along with the late D8H46A's.
Greg
bruce oz
australia
d7e
hello ,d7e 48a479*? was built in 1964 160hp d339t engine ,updated to 180hp after serial number 48a6885 in 1966 ,my book shows weight as 34000 pounds ,bruce oz
cgfreeland
Texas
Thanks for all your help. I'm a little dissapointed as the equipment dealer told me it was a 180hp version. Was the 180hp a different engine entirely? or rather what was done to make it a 180hp. I gave 23500 for it and it is about 0-85 percent undercarraige with all original undercarraige. Did I get riped?
cgfreeland
Texas
i put the * in the serial number casue I didn't know if it was smart to post the whole number on the internet ornot. Also, I am assuming that the ironrecord weight is for the bare tractor only and not the weight including blade.
Greg
Wi
Upgrade to 180 HP used the same base 339 engine. Just gave it more fuel and air. I am not sure if they increased the engine speed. I can't imagine it having the original undercarriage unless it has had almost no use. If the bottom is good, you got a good deal in my opinion. I run 7E's to this day pulling pans.
