All three of them.?I’ve pulled the axle shafts,
Yes all 3. And slid that collar leftAll three of them.?
I really think the front is released because when I watch it as someone torques the bolts it moves rearward and then comes back when they take bolts out. Something binding it seams but I guess we could throw more bolts on it and keep tryingSounds like you have everything right. The sliding collar will only move over about an 1 1/2”.
I wonder if the big O-Ring on the front collar is binding enough to hold it back. Some of them do take a fair bit of torque on the forcing bolts to come out. Just make sure you have all the mounting bolts completely out around the rear flange.
Maybe post some pics of the rear of the machine.
We all love a good rear end pic.
Yes I’ve got it out now. Must just have been that rubber seal that was holding it back. Took a lot of force with all 4 force bolts with longer thread to break loose. We’ve got it out and cleaning it nowyou remove the round plate behind the spider drive.
Is there much debris in it.?We’ve got it out and cleaning it now
No. Just real dark oil for the most part.Is there much debris in it.?
Never in my life has the rubber seal been an issue, the drive was not pulled off enough chap, when you drain out all the oil from the back tray you will see enough crap don't worry, it takes a small speck of crud to stop the modulation valves from working, another important thing to do is drain down the Transmission filter case and clean the bowl out, the drain plug is under the fender, remove the plug from underneath before you lift out the filter cartridge, you are going to need the clean up filter fitted after this major mash up you have.Yes I’ve got it out now. Must just have been that rubber seal that was holding it back. Took a lot of force with all 4 force bolts with longer thread to break loose. We’ve got it out and cleaning it now
Do you have a Part Number off the top of your head Tony.? I thought about it yesterday but when I looked at the standard filter element P/N I couldn’t see a cleanout element equivalent for it.you are going to need the clean up filter fitted
What exactly is the Code Number and suffix.?Get a code that’s not shown up before and that’s “torque converter output speed sensor intermittent/ erratic” .
Here you go. Transmission output speed sensor #2. See attached.673-2
