D6T codes
C>D>
codes for d6t c9 engine codes 036 100.04 - e 0198.2 - 0198.1 0360.3 - 0360.1
:notworthy
Out of your list there is only one actual diagnostic Code, the others are Machine Events.
MID036 CID0100 FMI04 - Engine oil Pressure Sensor - Short to Ground.
E0198.1 - Low fuel pressure - engine power is unaffected.
E0198.2 - Low fuel pressure - engine is derated while the event is active.
E0360.2 - Low engine oil pressure - engine is derated while the event is active.
E0360.3 - Low engine oil pressure - ECM will shut down the engine if this event occurs.
Note - there is no E0360.1 Event so I assumed it was 360.2.
