d9gdon
This D6T sn LAY907 has a problem with the blade. I have to wait on the blade to lower to make another push. I noticed (sometimes) if you tilt the blade at the same time as dropping it, it'll go down like it should.
On the other hand, you can start lowering before you get where you are going.
It's so the computer game generation doesn't strain themselves opening a hydraulic valveYair . . . I know I'm banging the same old drum but why the hell does a simple up/down valve ever need an electronic or pilot calibration?
Why put an extra layer of complexity over a very simple function . . . it's like counting the feet in a pen of bullocks and then dividing by four to get the number. . . sheesh.
Cheers
Systems today are to complicated, older valving was simple, the further you pushed or pulled the lever the faster it worked. IMO the ease of operation has gone beyond what is necessary and has cost reliability. It's not that big of a deal if you are working down the road from a dealer but if you are in a remote area or even another country and can't work because your dozer won't go down it becomes a very big deal.
