Metalman 55
I purchased this D6T ser # GMK xxxxx a few months back with about 9,400 hrs on it & it seems like a pretty decent machine for being an 11 yr old unit, however, especially in the warmer weather after the hyd oil heats up, the blade up function speed suddenly slows down, with the blade up power being compromised as well. It is a sudden change & is quite predictable after about 90 minutes of operation. Once cooler, all is as normal. We swapped out the electronic blade up control with ripper down (same part #) just to test it & the problem persists when warm, still quite functional, but just lazy, which effects the operating performance somewhat. Just wondered if anyone else out there has experienced this problem & could shed some light on the subject? Thanks
