D6R XL II SN#AAX00576
As i was pushing a load, tractor suddenly stopped as if put in neutral. As I lifted the blade it wanted to move forward but felt as if transmission was slipping. Reverse works as it should. Prior to this I noticed that there was a delay when shifting to forward from reverse and the delay got longer as time went on.
After reading a similar case on this forum and talking to the Cat tech, I replaced the the modulator valve #1. Started up tractor and it worked for about 1 hour and then did the same thing, stalled. I let it sit for around 10 minutes and started it up and again, it worked but only about 20-30 minutes Also noticed that when I turn off machine and turn back on, it seemed to possibly reset something and would also work for 20-30 minutes.
Anybody have any suggestions as to my next step?
Thank you in advance for you help!!
Robert M
Robert M
