D6R questions
Discussion in 'Dozers' started by KS8780, Dec 11, 2020.
  1. KS8780
    KS8780 Member
    Dec 7, 2020
    15
    Kansas
    First post from a new owner.
    I bought a 2000 model D6R the otherday and got it home yesterday. I have a manual ordered but hasn't shown up yet but was wondering what fluids it takes ?
    I have Cenex Quicklift HTB on hand here for my tractors and know that CNH Hy-tran meets Cat TO-2 specs and I run that in a Twin-Disc 12 speeds I have in a couple of my 4wd tractors. I just don't know what this 6 calls for right now
    Hyd, Trans, finals and whatever else.
    Is the trans fluid checked cold or warm? Running or not?
    Thanks.
  2. DB2
    DB2 Senior Member
    Jan 4, 2015
    720
    Winnipeg MB Canada
    Welcome to HEF KS8780.
    Will definitely help to include your serial number .
    Cheers
  3. KS8780
    KS8780 Member
    Dec 7, 2020
    15
    Kansas
    Yes it would. 5LN2787
  4. DB2
    DB2 Senior Member
    Jan 4, 2015
    720
    Winnipeg MB Canada
    I’m sure one of the Cat gurus will chime in shortly.
  5. Nige
    Nige Senior Member
    17,456
    And is if by magic .........
    Refill Capacities
    Fluids (for your location)
    Engine - SAE 15W/40 a minimum of API CG-4 spec
    Power Train - SAE30 TO-4
    Hydraulic - SAE10W hydraulic, or 10W TO-4. Makes no difference.
    Final Drives - SAE50 TO-4
    Recoil Spring Compartment & Pivot Shaft - SAE50 TO-4
    TO-2 was superceded by TO-4 about 20 years ago.........
    Transmission oil level is checked with oil at operating temperature, transmission in neutral, & engine idling.
    Were you aware that you can download a genuine copy of the Operation & Maintenance Manual in pdf format from the internet for around $50..?
    Tarhe Driver, KS8780 and DB2 like this.
  6. KS8780
    KS8780 Member
    Dec 7, 2020
    15
    Kansas
    Just what I needed. Thanks
  7. Nige
    Nige Senior Member
    17,456
    If your manual was a paper one I hope you didn't pay more than $57 for it even if it was new. See below.
  8. KS8780
    KS8780 Member
    Dec 7, 2020
    15
    Kansas
    Nope....$49.99
    Good news is I was able to run the dozer for 4 or 5 hours today pushing out a pond and really couldn't find any problems with the machine. I did get into some muddy stuff and learned my lesson of staying out of the mud. Didn't get stuck but spent alot of time cleaning the undercarriage out when I got done
  9. KS8780
    KS8780 Member
    Dec 7, 2020
    15
    Kansas
    One thing I noticed. The blade tilt doesn't seem to be using the full range of motion. It will tilt the left end down a bit bit will not tilt the right end down much at all. I swear it worked correctly when I inspected the machine earlier. Hyd. cylinders , one on each corner, only stroke a couple inches at most. They look like they should move more but I am not sure what the stroke length should be. I haven't looked but by the way the tilt valve feels it is all mechanical linkage (maybe it is pilot control idk) and it has full range of motion on the lever.
    Any ideas? Waiting on a service manual and thought I would ask here.
    5LN2787
  10. Nige
    Nige Senior Member
    17,456
    Tilt Cylinders are listed as 4" stroke so not much movement.
  11. kshansen
    kshansen Senior Member
    Mar 11, 2012
    9,071
    Central New York, USA
    I'm far from an expert on anything to do with dozer but I know one we had the amount the tilt moved was related to the angle of the blade. Been too long since I touched it but do recall something along those lines were I thought there was a problem but then when I changed the angle of the blade found that it made a major deference!
    sled dog likes this.
  12. kshansen
    Mar 11, 2012
    9,071
    Attached is a little information from SIS on this D6R.
  13. KS8780
    KS8780 Member
    Dec 7, 2020
    15
    Kansas
    Thanks. I had found that build info in SIS. Good info to have.
    I had the machine running yesterday and the blade tilt seemed to work correctly. It tilted much farther than it did when I ran it several hours the other day. Not sure what is going on but will see how it does when I get it back to work.
  14. Nige
    Nige Senior Member
    17,456
    Had'nt got a rock stuck somewhere in the linkage that it shouldn't be by some chance..?
  15. Oldcatpusher
    Oldcatpusher Well-Known Member
    May 30, 2019
    140
    Arkansas
    I found this old decal that came with my R the other day
    KS8780 likes this.
  16. KS8780
    KS8780 Member
    Dec 7, 2020
    15
    Kansas
    Stick seemed to have full range of motion. The blade would tilt to a point and then just stop. Would tilt further left than right but still not as much as it should. Maybe I have a cylinder bypassing when the oil warms up?
  17. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,644
    Am I right in thinking that you have a manual-angling blade with dual pitch and tilt cylinders? Electric switch on the blade control handle?
  18. KS8780
    KS8780 Member
    Dec 7, 2020
    15
    Kansas
    Yes, manual angle. Yes, dual pitch/tilt and NO electric pitch/tilt.
    Control handle left and right for pitch/tilt and forward and back for blade lift
  19. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    5,989
    On A Riverbank in IL. USA
    Could you post a photo of each side of the blade ?
    I for one am confused.
    Manual angle ? I haven't seen one of those since I worked on a pipeline 40 odd years ago.
    I thought you were asking about the tilt. There usually one cylinder (RH side)on the draft arm for tilting the blade and a big threaded rod on the opposite side. Tilt is controlled by pushing the control lever sideways. Push to the right and the RH corner of the blade goes down.
    Changing the length of the big threaded rod will change the Pitch of the blade. It also drastically changes the amount of tilt you will have.
    I rarely needed to change the tilt. Only in certain situations when cutting finish grade and the the blade would dive in uncontrollably.
    Just like Ken described.
  20. Cmark
    Cmark Senior Member
    Jan 2, 2009
    2,644
    I thought so. That's quite a rare bird you have there, but I'm a little surprised there's no switch on the handle. That would mean you don't have pitch control, only tilt.
    So when you move the handle to tilt, one cylinder goes in and the other one goes out, correct?
    In fact what you have is a gen-u-ine Cat custom product. Air suspension seat as well?
    Nige and Tinkerer like this.
