powerjoke
- Joined
- Aug 2, 2009
- Messages
- 1,125
- Location
- Missouri
- Occupation
- owner/operator/estimator/mechanic/grunt/ditchdigge
In addition to the other thread about my new to me dozer and the u/c fiasco I thought I would start this thread to help with some ideas,
This AKM machine has a little bit of a blade drop issue, it'll drop 4" in 15 seconds and if you try to pick up the machine it will not raise the tracks off the ground at an idle, as soon as you full rev the machine it lifts the machine like it should however as soon as you let off the control lever it slams the machine down on the ground as if you hit float..
Have no leaking cyl to speak of (one has a gland seal wet but not streaming or dripping fluid), has no leaking lines that I can find, I am wondering if it is in the valve body or if it needs calibrated I believe it's elec/hydro (has the thumb rocker for blade angle) as it is an ARO ready machine and I believe it has had a gps system on it at one time as there is a missing "gps on-off" switch on the dash (not a factory decal/sticker)
My thoughts are that maybe the ARO system is somehow not holding the blade ?.... It's either that or valve body is leaking internally, I have not had the chance to cap off lines and try to isolate it but I can't see how that would really help narrow anything down as there is no visible leaks we know the valve body is passing fluid right??
If it does infact take calibration for the blade control could someone please email me procedure
The machine just came in from TT&E-inc and was not disclosed to have this issue (or any of the other problems it has for that matter) but they told me they would not help get the machine repaired to what it was represented as when I bought it (sight unseen) and that I was on my own send me a pm if you really want to know what I think about Henry and Scott
Pj
Pj
