D6K
Ms
I have a D6K it’s throwing a code 1705-6 which means (Right drive pump forward solenoid current above normal) I replaced the solenoid and owned out the wiring has anyone else had this problem
Does that mean I need to run a new ground wire
No, most likely the power supply side of your sensor has a short to ground somewhere in the wiring.
Try this procedure and see if it helps. A machine Serial Number would get you the complete electrical schematic for it showing the location of all the harness connectors. That would probably help you to find the fault because a bad contact in a connector is generally the first suspect for this type of problem
  • CID1705 FMI06.pdf
Ms
I would like to update y’all I replaced the wire and my D6K been working fine thanks for all your help
