I've got a loose dead axle on one final drive. By marking the position of the outer hub and checking it I can see that the axle has turned some a couple of times. The last time I had it worked on it was very marginal on the taper so they tack welded the inner end of the axle to the case in hopes of keeping it from moving. The weld didn't hold and now I'm back to figuring out a repair.
The good way to fix it is to bore out the case and put in a bushing to renew the taper. I talked with Cat a while back, and to make a bushing, bore it, and install was quoted at $8,500....ouch.
Rather than have them do all the work, I thought I'd use a local independent shop, make up the bushings myself, and have Cat come out and just do the bore.
Well, that'd be fine but Cat doesn't have the bushing and won't let loose with any info on the bushing itself.
Does anyone out there know of a source for the bushings, made up their own bushings, or have dimensions for the ones Cat used to supply? Short of getting a new dead axle, taking measurements from it, and making up my own bushing I'm not sure where to go from here.
